spadoctor wrote:
As for the 20's....the fed regulation says no more then 17 lbs in them now because of issues with the OPD floats. That's why the exchanges have gone to 15 lbs. There is no lower fill requirement on the 30's. This per 2 LP dealers and my county health dept that does weights and measures
vic46 wrote:
Are you saying that the 80% fill limit is not mandatory on 30# tanks?
A 30 lb tank when filled to 80% capacity
will contain 30 lbs of LPG. Check the collar on any 30 lb tank and it will have a WC (Water Capacity) rating of ~ 71.3 ... 71.3 x .42 = 29.946 lbs. This has nothing to do with OPD valves which have been mandated since the late 90s ... wherever
spadoctor is getting his info it's incorrect.
