Bumpyroad's avatar
Bumpyroad
2005 VUE warning lights
my wife reports that a warning light goes on and after a while goes off, a picture of a radiator? like figure beside the 8 on the tach. and she says there is nothing listed in the manual for this.
she stopped at a service station and they thought it might be low fluid but they only added a small bit of water to fill it up.
any ideas?
bumpy
  • JesseJ1826 wrote:
    That light indicates low coolant level. If the level in the coolant reservoir is right up and you have no overheating issues I suspect the sensor in the tank is dirty or failing. I suggest you check with the "experts" here www.saturnfans.com/forum Go to Models then to Saturn Vue, and put your question to them.
    thanks for the info and the link. it is a little difficult to find a Saturn dealer now days. :)
    had to drop the "forum" for some reason to get there.
    bumpy
  • That light indicates low coolant level. If the level in the coolant reservoir is right up and you have no overheating issues I suspect the sensor in the tank is dirty or failing. I suggest you check with the "experts" here www.saturnfans.com/forum Go to Models then to Saturn Vue, and put your question to them.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
