Grit_dog
Aug 15, 2016Trailblazer
Ya try towing again and make sure it's locked in drive/3rd gear and check the temp.
Letting the engine wind up is better than bogging the trans and final drive ratio down.
It won't be first up the hills but no reason that rig shouldn't to be able to tow 6klbs in the flats without issue.
Other not horrendously expensive mods if still running too warm and you don't have another obvious issue is deep trans pan with cooling fins, second trans cooler if you can get it plumbed in somewhere.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
