Grit_dog
Aug 16, 2016Trailblazer
Jpedigo wrote:
I think I need to just slow down. I normally drive between 58 and 65 so I am probably working that tc. I did read the owners manual and it said I can tow in 3rd. I may try that to see if it lowers the transmission temp.
There's no may about it. If you were dogging it in 4th/OD then it ran considerably hotter than if you were in 3rd with enough power to keep the converter from unlocking.
I think you'll be fine with your setup although additional fluid capacity and cooling will help a bunch as well. Have to remember the limits of what yer driving. You're not going to be able to keep up with the HD/diesel crowd with a 10 year old half ton.
Good luck, btw always like the Z71 models. They're cool!
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
