- SoundGuyExplorer
drsteve wrote:
I'd be really surprised if it is not 2 5/16.
For some reason the OP still won't tell us which model of Aspen Trail this is but it's coupler is most assuredly 2 5/16". ;) - drsteveExplorerI'd be really surprised if it is not 2 5/16.
- Golden_boysExplorerAm checking that out. Thank you
- bikendanExplorer
beemerphile1 wrote:
Should be stamped on the trailer's coupler.
That's what I said but the OP didn't respond. - beemerphile1ExplorerShould be stamped on the trailer's coupler.
- SoundGuyExplorer
Golden boys wrote:
No, Dutchman did not respond. 2" didn't work guess I'll try the 2 5/16 ...
Only a very few, quite small travel trailers would have a 2" coupler, with 2 5/16" by far being the most commonly used on everything else. Unless your Aspen Trail is particularly small (which you never indicated) it will definitely have the larger size coupler. - Golden_boysExplorerNo, Dutchman did not respond. 2" didn't work guess I'll try the 2 5/16, thank you all. SemperFi
- bikendanExplorer
Golden boys wrote:
What size ball is needed to attach to pick-up
ball size is stamped on A-frame.
since you don't list trailer model or size, it's either 2" or 2 5/16" - mat60ExplorerI'm thinking a 2-5/16 but not positive on your model. I just picked up a camper and took a 2in with me also just in case.
- LwiddisNavigatorWhen you asked Dutchman they didn’t reply?
When you asked the dealer or private party they didn’t respond?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
