JBarca
Dec 30, 2012Nomad II
dragr1 wrote:
I've been reading the equalizer instructions and it looks like I need to add maybe 2 spacers to tilt the head more. I looked on mine and it has 4 spacers on there right now and of course they didn't give me the rest of the spacers from the shop. So I'll have to get some or is this just a common washer that I could buy somewhere local?
I would do 2 things.
1. Contact the dealer and ask him to mail you the spacer kit that came with the hitch. They were all there at one time.
2. If you need to use the hitch until the dealer supplied ones show up, get some grade 8 flat washers and use them.
The fine thread bolt on the bottom is to take up the play of the assembly when you have the hitch head loosened up from the shank. The bolt puts some preload on the upper pin with the spacers until you torque up the 3/4" bolts on the shank. This way the pin is dead tight agasint the shank before you tighten the 3/4" bolts.
Hope this helps
John
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
