JBarca
Jan 03, 2013Nomad II
dragr1 wrote:
So to go 2.5" but with a 2" shank, I'll have to deal with this gizmo?
http://www.curtmfg.com/part/45405
When you buy a 2 1/2" reciever it works like normal on 2 1/2" shanks. Stick shank in, put longer then normal 5/8" pin in to work on 2 1/2" shank.
When you have a 2" shank and want to use it in the 2 1/2" pin box, you use that 2 1/2 to 2" adapter sleeve that you linked to. It slips over the 2" shank and adapts (fills up the space) to make it work in the 2 1/2" reciever.
If you are using the adapter sleeve on a 2000 GVW little utility
trailer and only say 300# TW, there can be some wobble as there is not much weight to take up excess slop. How bad depends on the fit. If you buy a Curt reciever, buy a Curt adapter. Buying some other brand can some time results in it won't fit (Ford had this issue) to being really sloppy.
Hope this helps.
John
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
