dragr1
Jan 23, 2013Explorer
JBarca wrote:dragr1 wrote:
I have another question unrelated to the original topic-does opening the low drain point valves drain the water heater?
Generally no. The low point drain on many campers is just T'eed into the water lines. On an Atwood or Suburban heater you have to pull the drain plug on the heater and vent the heater to allow water to come out.
FYI, while the low point drains do drain some of the water out of the lines, pending the TT layout and the way they put them in place there can still be a large amount of water left in the lines.
I drain and blow out the water after each trip. Before I leave camp, I have a quick opening valve on the HW heater. I open the low point drains, drain the HW heater, open all the faucets at the camp ground to break the vacuum and vent and then let them stay open on the way home. By the time I get home a lot more water has left the system than just draining static with the TT in place.
I redid the piping to allow me to blow out the system starting at the water pump forward. If not many floor plans allow several feet of water in the pipe from the pump to the main distrubtion line with water in it.
Good luck. Glad your trip went well. Will type more tonight on your instability while towing.
John
I opened all the faucets and low point drain before I left the campground and drove home like that. I tried to install one of the quick drain valves on the water heater but it leaked really bad so I put the plastic one back in. I'm guessing that I should have used teflon tape on the threads for the quick drain valve? Didn't have any with me at the campground.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
