Niagara_Falls's avatar
Oct 14, 2013
2012 GMC Sierra / Size of TT?? (NEWBIE)
Looking for opinions from some experienced people. Have a 2012 GMC Sierra 4x4 Ext.Cab. 143.5 WB, 5.3 L, 3.42 gears, with tow package..
Manual States That I Can Pull 9600 lbs. Wife Wants a Big Trailer 26 to 28 ft Length, I prefer something in Range of 22 to 25 Ft.
Something That The Truck Can Handle Easier!!
We are new this, so any help in this matter would be greatly appreciated. Plus which TT manufactures are good and ones to keep away from..Thanks
  • pitch wrote:
    Open the driver door of your truck. The label will say weight of passenger and cargo should never exceed xxxx or language to that effect. Figure every thing that is going to go into the truck,do not forget the hitch system will weigh about 80#. Subtract all that weight from xxxx, the remainder is your cargo and tongue weight capacity.
    Look at the maximum loaded weight of the trailer ,sticker located usually on left front corner. Tongue weight will be 10 to 15% of that.
    Do not exceed!
    Matching a truck and trailer is not the mathematical problem some make it out to be,just use common sense and don't push the limits.
    You described a math problem and then said it's not a math problem. :?
    I think for newbies without towing experience, the math problem is the only way to approach this. (In fact, I completely agree with the first quote above except for "it's not a math problem".)
  • ependydad wrote:
    Snip...
    He did not say it was not a math problem. What he said was "it's not a mathematical problem that some make it out to be". (my bold) That is a different statement than what you are implying.
    Barney
  • BarneyS wrote:
    ependydad wrote:
    Snip...
    Barney
    (sigh, this sounds so persnickety and it's not meant to)
    I still don't get the distinction?
  • OK OK it is an arithmetic problem.
    I just wanted to point out to a new guy that when he see the inevitable spreadsheets, algebraic formulas, and such not that accompany posts on this topic,not to get overwhelmed.
    Fair enough and I wholeheartedly agree. Sorry 'bout that.
  • CKNSLS wrote:
    About 11 months ago I completed an 8 month-8,000 miles-32 state towing trip with my 2011 Crew Cab Silverado w/the 5.3. and a 5,500 pound 29 foot travel trailer. There are PLENTY of ULTRA LIGHT choices you have. Keep the dry weight less than 6,000 pounds and one to NO SLIDES. Those things weigh 300 pounds a piece.
    As an aside-I put an additional 10,000 miles on the truck "touring the sites". I had ZERO issues with truck and trailer. No even a flat tire.
    PM me if you need any further help since I have actually done what your looking to do.
    X 2
    Our TT is 30 ft and is 5500 lbs with a slide. They are out there.
  • Had a 28 foot Jayco for years and an Avalanche with 5.7 (?) and 3.73 gears. In a head wind would struggle to maintain 65mph. Mountains were another problem the best we could do (in Canada) was 35mph and sometime 30.
    Go find the trailer then look on line or go to a camp ground and seek out what TV works for them.
  • We tow a Camplite 21BHS with a Ram 1500 - 4.7L. Dry weight of 3500 pounds and max weight of 5000 pounds. Tows great and easy to handle. Not what you're looking at but very comfortable, especially for two. Plenty of room and can sleep four without touching the dinette in the slideout (queen bed and two bunks). Just mentioning in case you're considering alternatives.
    Camplite Trailers from Livin Lite
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
