NamMedevac_70
Jul 25, 2021Explorer II
Do you have an auxillary transmission cooler and extra fan??? I have used in 3 different Ram 1500 and 2500 trucks the green bottle of Rislone Hyper Cool water wetter coolant with dramatic cooling results in extreme hot weather running the AC in city stop and go traffic. Better than the Red Line water wetter I used to use.
Sometimes in older vehicles the lower radiator hose will collapse or partially collapse under high heat load stress but yours probably has the spring inside the hose. My last issue of truck overheating was due to air bubble inside the radiator but a radiator flush solved that problem.
Check your radiator cap pressure and they can do a thermostat check for intermittent operation.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
