BenK
Aug 03, 2021Explorer
DIY’ers drill a 1/32” hole at the very most low point in the inter cooler plenum so condensed water will drain. Higher PSI in there pushes it out faster
Ford had a similar hole as an OEM solution in later models
dfreddrickF150 wrote:
The cooling system checks out. The last two dry runs the motor has been missing badly at higher speeds (65). They call it the Ecoboost Shutter. In humid climates, condensation builds up in the intercooler and on high demand sucks it up into the intake. There are some shade tree fixes but Ford has not given an official fix for it. Still searching!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
