hipower
Apr 17, 2013Explorer
rmmpe wrote:
I have a 2013 Focus SE that I will be towing. I also have a Roadmaster Even Brake that will be used.
However, the Focus's brake lights do not illuminate or send a signal to the Even Brake without the key being in the on position. Roadmaster sells an adaptor to get a signal to the Even Brake but that doesn't solve the problem of not having the Focus's pedal actuated brake lights.
Has anybody run into this problem and if so, how did you get around it?
I encountered the same thing when setting up my Silverado with the Even Brake.
It's been several years and I don't remember the details of how we overcame it, but we tied into a hot wire prior to the stop light switch, installed a one way diode and a switch to control the power source.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
