Bill_Diana
Jul 12, 2014Explorer
2013 Honda CRV...now what???
Last year I traded a 2004 Honda CRV for a new 2013 Honda CRV. The 2004 CRV served us well as a toad. Simply follow the directions in the owners manual for towing 4 down behind the motorhome. The 2004 never needed any special battery charging arrangement.
But the 2013 is a different story. On our first trip with the 2013 CRV I found the battery to be dead at the end of the first day. I followed the owners manual but did not pull the fuse as I did not think this would be necessary since I never did it with the 2004 CRV.
So I decided to fabricate a fuse bypass switch to make the fuse removal process easier. That worked fine. No more dead battery in the 2013 CRV but then I discovered a new problem. The fuse bypass switch also cut the power to the cigarette lighter socket that I was using to power the Brake Buddy.
Are the rest of you having this same problem when you pull the fuse or use the bypass switch?
