- ksg5000Explorer
DrewE wrote:
At 100 hours, you probably don't need to do anything.
x2 - DrewEExplorer IIAt 100 hours, you probably don't need to do anything. What you're seeing is most likely the fuel pump, I suspect--typically a metal cylindrical object with the fuel line going in and out and (if you look closely enough) wires to power the pump.
- luberhillExplorerI don’t see anything, except buried in the back corner of the gen cabinet looks like maybe a metal one,, no clue how to get to it or with 100 hrs if I even need to
- gboppExplorerCan you follow the fuel line back to the gas tank?
I know the older Onan generators have a small filter where the fuel line enters the carburetor. - luberhillExplorerIt’s a Onan 4000 gas
- Not enough information. Need model and gas or diesel. Did you check out on the onan/cummins website for information?
- T18skyguyExplorerI don't know about a 2013 Onan, but when I had a 1996 there was a fuel filter. It was located at about where the fuel line enters the genny enclosure. I bought a new fuel filter, but sold the rig before I installed it.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
