willald
11 years agoExplorer II
lanerd wrote:
What is the advantage of a "plug in" over a regular hybrid? We are currently looking at hybrids for a family car...not for a toad.
Ro
A 'plug-in' hybrid typically has larger batteries, and can therefore store more electrical energy. Allows you to charge up the vehicle's battery from an external AC source, and in some cases this allows the vehicle to run 100% on electrical power and use almost zero gas.
It comes at a very high price, though. Typically a plug-in hybrid will cost several thousand more than a regular hybrid. In some cases, though, that higher purchase price is offset by various tax breaks you get with them.
A regular non plug-in hybrid OTOH, doesnt have as big a battery, and gets all its electrical power for the batteries from regenerative braking and from re-charging that takes place when running on gas. It can't run completely on electric power for as long, and typically will run on gas engine a little more often. Will use a little more gas, but also costs significantly less (several thousand) initially.
In the case of Ford's Cmax and Fusion hybrids, both (plug-in or not) are completely flat-towable.
Its important to note, like already said, that whether its a plug-in hybrid or regular hybrid, both can run on gas or electric power. When battery runs out, you are NOT dead by the side of the road. It has a fully capable gas engine that will then take over and can provide all the power needed, so long as it has gas in the tank. :)
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: 1 day ago
