cire
Feb 19, 2016Explorer
I have a 2014 CRV with a Roadmaster system. I love it. I previously had a 1999 CRV with a Roadmaster system. The new Roadmaster system is great. I fancy myself pretty aware of all the available systems. The following detail is the reason I am so pleased with the Roadmaster base plate. I ordered the -5 option. Sorry I'm too lazy to dig up the full number of the base plate but the -5 option is great. It's light (5#-8#) for each side. Easy to remove and reinstall. Does NOT require the cross bar usually required on Roadmasters. And it looks great when you remove the two pieces.
The only thing that is visible on the front of the CRV when you remove the attachments are two rings, about 1.5" each. There are also two tabs that project for attaching the safety cables. (These two tabs are nearly invisible.) I want to add that it is incredibly easy to remove or reinstall the attachments. You bend down, pull a spring loaded pin, rotate the attachments 180 degrees and pull out. You don't need to get on your knees to disconnect.
Good luck on your choice.
Eric
currently in Las Vegas
Eric
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
