mlh
Jun 08, 2014Explorer
I just bought one and installed the baseplates, wiring, etc. I bought the baseplates (roadmaster) from PPL motorhomes. Their price was as good as anyone else's and I've ordered from them in the past with good results. I got the wiring harness from cool-tech. It was pretty simple to install as well. I ordered the deluxe kit which also came with a negative battery disconnect. I later found out that there is no steering lock so you don't need to leave the key in to keep the steering unlocked. Hence, I did not install the battery disconnect. I did verify by turning the wheel while the key was out and it did not lock the steering. Other than that, I plan to follow the owner's manual for the instructions on how to set up for flat towing. I have never towed my or any other jeep before so it will be a first. I used to tow a Nissan frontier crew cab a while back, so I know what to expect with that much weight. Good luck with yours.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
