lcommerford's avatar
lcommerford
2014 nissan pathfinder
i have a 2014 2 wheel drive nissan path finder ana want to upgrade from a pup to a hybridtt….does anyone have a definitive answer as to how much i can pull with this ….car specs say 5000 lbs but hearing that is not the actual …thanks
  • Small hybrid shouldn't be a problem. Watch your weights and frontal area.
  • I believe the 05 pathfinder was still body on frame construction. The newer ones are uni body. Totally different vehicle unfortunately
  • I have a 2005 Pathfinder with a 6000# tow rating and pull a hybrid with GVW 4950lbs. I'd say if you keep it under 4000#, you may be ok with that model year Pathfinder. Just check your weights and take it easy. Although our '05 tows it ok, I wouldn't go up the mountains with it.
  • That 5000 lbs tow rating, does not allow any weight for aftermarket accessories, passengers, and cargo. As you add those things, your tow capacity and available payload are going down, pound for pound.
    Check your drivers door post. Look for a tire / loading sticker. It will give you a number for max occupant / cargo weight. Take that number and subtract weight for all the people and stuff you would normally carry in the vehicle.
    Whatever is left, divide that number by .13. That will give you a ball park number for trailer weight that will put you close to max.
    Example:
    Say the loading sticker says 1000 lbs, you have 600 lbs of people and stuff. Divide 400 by .13 to get a 3076 lbs loaded trailer weight.
    Keyword in the example is "loaded" trailer weight. That means, when the trailer is ready to go camping, it weighs no more than your estimated loaded weight.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
