seminole39's avatar
seminole39
2014 Ram 3500 brake controller issue
First post here so please have patience. I have an issue with a new to me 2014 Ram 3500 DRW 4x4 CTD. I am towing a 2012 Heartland Greystone 33CK on an Andersen UH coupled to the factory gooseneck hitch. My issue is this: the truck had factory trailer tow prep including 7 way plugs in the bed and bumper as well as the above mentioned gooseneck hitch but no factory trailer brake controller. I purchased a factory controller, installed myself and had to dealer flash the computer. All was well, the trailer settings would appear on the screen after the computer flash. I hooked to the camper for the first time, plugged in the 7 way in the bed plug, all lights function correctly (running lights, turn signals, brake, etc) but when scrolling through the menu to trailer brakes the truck displays TRAILER NOT CONNECTED. I tried the 7 way plug on the bumper and same result. I then proceeded to unplug every trailer wiring plug under the truck, clean with contact cleaner and dielectric grease and reinstall with no change whatsoever. Just for S&G I unhooked the camper and backed under my gooseneck float trailer and got the same message. I am at a loss due to I know for a fact the brakes on both trailers are in good working order as they were used regularly with my previous truck, 2008 F-350 PSD, with no problems at all. Sorry for the long winded post but what say you experts?
  • So you installed the module under the dash with the two connectors?
  • Have you isolated the problem to the truck? Check the plug for applied voltage to the trailer brakes (pin 2) when the truck brakes are engaged.
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
