j wackerly wrote:
hohenwald48 wrote:
Like I said, Ford designed the chassis and specified the welds to hold the body panels, doors, bumpers and other components, in place under normal use. The owner, in conjunction with the baseplate installer and manufacturer endeavored to modify the vehicle to serve a function not considered by the Ford design engineers. Any failure of a vehicle caused by an unauthorized modification is the responsibility of the person making the modification. Ford has no control over how you decided to mount the tow bar. :R
According to your logic, if I decided to mount a 5th wheel hitch on the roof of a Camry and pull a 40' 5th wheel around, Toyota should be responsible if the roof couldn't handle the stress
As to the transmission, based on post #1 I thought this was a thread about a tow bar failure.
The reason i posted this post was to make aware this could happen to anybody that tow a Ford Focus . I purchased this car because Ford said it can be flat towed as stated on page 185 of owners manual. And roarmaster base plate will work on this car per instructions . As a consumer who can you believe ? The only way this could be avoided is to have a full frame car .
Or a better engineered tow bar baseplate. When they provide the little short safety cable to go from the baseplate to some other location on the vehicle that should raise a red flag.
Thanks for making everyone aware that Roadmaster makes a sub standard baseplate for the Focus. Maybe other Focus owners should consider other baseplate manufacturers.
