enblethen
Aug 07, 2015Nomad
Yes, the key stays in the rig. You can use your remote or another key to lock. That is if your rig will allow you to locate the rig with the key in the ignition.
I would install a switch setup so you do not have to pull the fuse. switch set up from Roadmaster
