cvbdsl
Mar 07, 2016Explorer
Ok, just a thought here, would I risk blowing a fuse if I took 12 volts from the plug on the MH ( I assume there is one pin with steady 12 volts) split the line and also used the same connector for the lights on the toad?
With both active at the same time (whenever slowing/stopping) I think the load might be too high?
Thanks
Chris
Thanks
Chris
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
