- HeisenbergExplorerRVI II
- FIRE_UPExplorer
peterman1 wrote:
hello
I have a quick question... what type of supplemental brake system would you use for a 2016 jeep wrangler sport 2 dr? thanks for any responses.
pete
Well Pete
You don't say what kind of coach/model/year/gas/diesel/engine etc. The reason I ask for that info is, there's supplemental braking for your Jeep that is primarily is designed to be used with Diesel coaches with air brake systems. One in particular is called the M & G Braking system. It is by far, the easiest to setup and one very important point/benefit is, IT DOES NOT PUSH ON THE JEEPS BRAKE PEDAL!! It's mounted between the power brake unit and the master cylinder. Therefore, no brake lights are triggered with the M & G unit.
The really nice benefit of that is, since there's no brake lights triggered, you can use the plug and play Hopkins harness for wiring your Jeeps tail lights for toad lights. I know, I just did it yesterday for our '15 JKUR Jeep. With the M & G braking system, all there is between the toad and the coach is a short, curly Que air line with a female at one end and a male at the other, DONE!
There is no lifing of any heavy "Robot" out of your toad and storing it some place and, re-inserting it, each time you want to hook up and travel. A One pound air line is all you'll attach between the coach and Jeep.
This all pre-supposing you MAY have a diesel. If not, well, you'll have to with another choice. Many use the Ready Brake due to it also is a permanent install, no robots to lift in and out of the toad.
Scott - BumpyroadExplorerone of my major concerns was wanting it to have some type of break away braking function.
bumpy - klutchdustExplorer IIReady brake.
- nevadanickExplorerI use M&G on our Jeep and did on our pickup as well. There are lots of options and i dont think there is a bad one, just different methods of doing the same thing. You have to decide if you want to rmove it each time you unhook or not and go from there.
- 2gypsies1Explorer IIIWe used Brake Buddy successfully with our Jeep for 8 years of our full-timing.
- Thunder_MountaiExplorer IIThere are so many choices. It all depends on how much you want to spend and how lazy you want to be. Lots of folks will chime in. I had a Brake Buddy that I used in four different toads. I now have an RVibrake2 that I bought at a local garage sale for $400. It had been used twice and was like new. After you decide what you want, start cruising eBay, Craig's List and Amazon. I sold my nine year old Brake Buddy on Craig's List for $200. Left some money on the table, but it only took 3 days.
- BumpyroadExplorerI powered my Brake Buddy with a portable charger/jumper jobby which I wanted to have along anyhow.
bumpy - 2005bounder35eExplorerBrake buddy
- talottoExplorerI use the Blue Ox Patriot Brake in mine.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
