Normph's avatar
Normph
2016 Subaru Forester
I'm considering buying a 2016 Subaru Forester to tow behind my motor home. The owners manual doesn't prohibit towing a manual transmission version, however I read in an FMCA magazine that the factory is now not recommending the car for dingy use. Does anyone have any comment or direct experience with the Forester?
Thanx
  • I think the main issue is that non of the 2016 Subaru's are listed as towable by Subaru. Tow at your own risk. Dick
  • Normph wrote:
    The Forester is a manual trans unit. The problem may have to do with the electric power steering. I believe they switched from hydraulic in 2014.
    my 2005 VUE has electric power steering and it is towable 4 down.
    bumpy
  • The Forester is a manual trans unit. The problem may have to do with the electric power steering. I believe they switched from hydraulic in 2014.
  • Most likely this is NOT towable four-down (unless it is manual trans). Subaru (and Honda) went to a CVT auto transmission in 2014 or 2015 and these are not towable.
    My 2014 Honda CRV is the last Honda auot trans that is towable. Had a Subaru Forester prior and went with Honda when I couldn't get an automatic Forester to work four-down.
  • exactly what does the owner's manual say under either "towing behind a motorhome" or recreational towing? if the mfr. does "not recommend" towing it, are you still going to consider doing it?
    bumpy
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
