rollindownthero's avatar
rollindownthero
Explorer II
Nov 14, 2018
2018 Jeep Grand Cherokee Limited Towing Capacity
I have a 2018 Jeep Grand Cherokee Limited with the 3.6 Liter, V-6 24 Valve VVT Engine, 8 speed automatic transmission, 4x4. Trying to determine if I can tow a small travel trailer.
I am trying to figure out what the towing capacity is. 1/2 the websites I see say 3,500 lbs the other half say 6,200 lbs. The official Jeep website says 6,200 lbs. I called the dealer where I bought it from and gave them my vin number, they told me 3,500 lbs. Even the manual says 2 different things. It says 3,500 with standard cooling and 6,200 with heavy duty cooling. Then I looked up heavy duty cooling systems and it says that they don't change the towing capacity. Camping World has a towing capacity that you can look up and that said 7,200 lbs. I checked the door sticker and it says nothing on that about towing capacity.
Who am I to believe on what the towing capacity is?
  • Believe Jeep.
    Or, do as others will surely advise you. Hook up what you want and go camping.
    If the dealer looked up and gave you 3500 per the vin number, then they should be right.
    What you have going against you are, motor, rear axle ratio, weight of the vehicle full of fuel and all occupants on board.
Looking for advice before your next adventure? Look no further.25,175 PostsLatest Activity: Nov 09, 2025
