Skinny_Man's avatar
Skinny_Man
Explorer II
Oct 02, 2014
225/75R15 tires
I replaced the tires on my utility trailer with take offs from our travel trailer. Both trailers have 225/75R15 tires. The ones from the travel trailer ended up being over 2 inches taller? Have any of y'all ever run into this before?
  • I agree with JIMNLIN that narrower rims could make a difference, but two inches is a lot.
  • The tires that were on the travel trailer had less than 300 miles when I took them off. I didn't trust them, China Goodyear Marathons. There is nothing wrong with them. If I knew how to post a pic I would.
  • Sounds like the tire that is two inches taller has separated tread/belts issues.
    Also a narrow width wheel can cause the tire to balloon the center of the tires tread.
  • I know there should not have been that much of a difference....but there was. I found it very odd. I just hope they will fit under the fenders of the utility trailer.
  • Unless one set of tires was low on air enough that the trailer sat 2" lower...they weren't the same. You might get a 1/2" difference if one set has fresh tread and the other is bald but it's unlikley to be 2" worth of difference.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
