Les_Steward's avatar
Les_Steward
2500HD ride
I have a 2012 2500 HD Cummins Diesel GMC and tow a 10,000 lb bumper pull. I have added two leaf springs on each side of truck. What can I do to improve the bumpy ride while towing the trailer?
  • Take the two springs you added off, buy a weight distribution hitch, install it and get it adjusted properly, and you’ll improve your ride by leaps and bounds.
  • rhagfo wrote:
    Well if you have a Cummins engine you have a Ram, if it is a GMC it should be a Duramax. Springs don’t fix bounce a good set of shocks should fix excessive bounce. Bilstein is a great towing shocks.
    I just replaced a set of shocks on my truck. Bilstein is the brand for me and has been since truck was new.
  • Why did you add leaf springs? A 10,000 pound trailer probably has a 1,200 to 1,500 pound tongue weight. That should be well withing the payload capacity of a 2500. Are you using a WDH? Is it adjusted right? I agree, put some good shocks on it, Bilstein or KYB Mono Max.
    How much air are you running in your tires? If you have them inflated to 80 psi it is likely too much. Weigh the axles and consult a tire load inflation chart and inflate accordingly. I would be 65 or 70 psi would be about right.
  • rhagfo's avatar
    rhagfo
    Explorer III
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
