da_bees's avatar
da_bees
2&5/16ths hitch on 2 inch ball !!!
I need to move a 5K Lbs tounge pull trailer 10 miles today. I don't have a 2&5/16ths ball and don't see need for one in the future since I have a fith wheel rv. I have a 2" ball with 1" shank rated for 10k. What are the odds of the hitch uncoupling or worse? I'm not concurned about tounge weight on the F-450, trailer has good electric brakes and traffic is light on level terrain.
  • Yes, get the right size ball. It can come off the 2". Another but more expensive option is the (Convert A Ball). Very versatile I have used them for the last 25 30 years. :)
  • Thanks guys. I will pick up one of the 3 way set ups suggested.
  • Golden_HVAC wrote:
    You can also find a combination hitch with three balls already installed. You rotate it to put the top one in that you need. So the 1-7/8" or 2" or 2-5/16" is rotated to the top when needed. It is all one piece, none of them remove, and I think they are rated around 10,000 pounds, depending on the design and manufacture rating.
    Fred.
    I bought one at Harbor freight for $19.99. then you can get 25% off that.
    bumpy
  • DO it RIGHT or ..........DON'T DO IT!!!!! If something happens to the trailer who do you think is at fault for the damage??? It won't be the owners of the trailer....
  • No way. Please don't do it!!! I made a mistake with a utility trailer that took a 2 inch ball and I put it on a 1 7/8 ball. I didn't make it out of the driveway.
    Please please get a proper shank and ball.
  • I'd say go to WalmarK and buy the right ball. They're like $15.00 and the trouble it will save - it's worth it! Charge the owners for it and then give them the ball after you're done.
    WoodGlue
  • If it was from one side of a RV park to the other, with no dips in the roadway, I would say take it slow, less than 10 MPH.
    But one rough spot in the road, or a ditch, or something can pop the hitch off the 2" ball. Buy a 2-5/16" ball and charge the people who want the trailer moved. You will be paying more for fuel than the ball cost will be.
    Finding a 2-5/16" ball with 1" shank might be a problem though. THey might have 1-1/4" shank, and thus will not fit into a 5,000 pound rated receiver.
    They are designed that way. The 5,000 pound receiver adapters will only fit into a 2" hitch, and 2" receivers come with a 1" hole, so that people do not install a 15,000 pound rated 2-5/16" ball on the 5,000 pound rated hitch.
    The 1-1/4" hole is in a solid receiver - part of a weight distribution system. They typically are rated at 10,000 to 15,000 pounds GVW and up to 1,500 hitch deadweight.
    Fred.
