1Longbow's avatar
1Longbow
3 inch grey water drain?
As I have posted on here ,we are having a problem with our grey water tank draining. It really takes about 35 minutes to drain the tank. I have pulled the drain pipe and washed out the tank and could find nothing plugged. The drain pipe is 1 1/2 inches in diameter. Would putting a larger diameter drain pipe help,or should I be looking somewhere else. I put a new vent cap on,but right now I'm at wits end,trying to figure this out. I don't want to put everything back together until I have exhausted all the options. gate valve works just fine. Any ideas or suggestions? Thanks to all of you.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 20, 2025
