coolmom42's avatar
coolmom42
Explorer II
Aug 31, 2020
30 foot run of sewer hose--downhill?
Looks like my closest dump location (into a sewer cleanout) at home is going to be about 30 feet horizontally and about 4-5 feet (luckily) downhill from the RV.
Is it feasible to run that much Rhino hose, or similar hose, that far? Would I be better off with some sort of rigid pipe that can be disassembled for storage?
I really don't want to buy a macerator pump, and doesn't seem it would be necessary.
  • Before I made changes to the property, I used 3” PVC. Now I use cheap hose from Walmart if I dump on the way in, or a macerater if parked in the garage. Storage of the temporary hose or pipes should be considered.
  • You'll be fine. It literally flows downhill.
    We have a very long triple axle fiver and I've had to link hoses together for longer, flatter runs than that. Everything ended up down the dump hole where it belonged.
    You're good.
  • Seon's avatar
    Seon
    Explorer II
    All you can do is try. IMO it should be alright. But then I like rope burns...Quoting the "Unknown Comic" on the Gong Show.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 11, 2025
