tim1970's avatar
tim1970
30amp power cord
I was wondering if anybody that has an RV wired for 50amp service carries a 30amp cord for when they know they will be at a campsite that only supports 30amps. It seems like it would be better than having to use the large 50amp cord. I guess I also need to know if you can even buy a 30 amp cord that will plug into an RV designed for 50 amps. (Is the connector the same?)
Thanks
Tim
  • fj12ryder wrote:
    Bumpyroad wrote:
    lawnspecialties wrote:
    I have both a 30A cord and a 30A adapter. But the thought of dragging that 30A cord around means it stays home 100percen of the time. I use it when the camper is in the driveway being loaded up for a trip. But it goes in the house garage before we leave.
    you don't carry a spare additional cord?
    bumpy
    I don't, never needed it. It could happen but hasn't so far in about 10 years of periodic travel. It certainly could, but not so far.
    Nope. Never needed it as well.
  • I needed an extra cord at a nice park in northwest PA. The trailer cord and the extra cord were stretched like a clothes line to reach.
  • 50 amp unit- I have both 50ft cables as well aadapters. 30 amp has 50 plug, lighter than the 50 amp.
  • If I were, I would. And yes, such an adapter is available. You may not find everything in your RV powered.
    With 30 amp service, I carry a 50-30 adapter in case I get into a site where only a 50 amp socket is available or it is the only socket working properly.
    Some RV parks might have adaptors for rent, but I carry my own, they don't cost that much, don't weigh that much, and I can buy at the quality level I prefer.
  • The point of carrying a 30 amp cord is so you can avoid using the much heavier 50 amp cord if you don't need to.
    Why get out the heavy 50 amp cord if you only have 30 amp worth of power available?
    Adapters do not eliminate the heavy cord from the equation. The OP's goal is to use the lighter cord when possible. The lighter 30 amp cord is available
    x2
    why is this "fact" so difficult for some to grasp?
    bumpy
    x2
    bumpy
    Because a percentage of humans will argue with a tree.
    I will leaf that comment alone. :)
    bumpy
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    That is why I have such a cord so SECOND on this post.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
