kfp673
Jun 28, 2021Explorer II
4 Bikes on luggage rack
Hello All,
Looking for some first hand experience and suggestions. We have a 2018 Outback 325BH that came with a luggage rack mounted to the back. The rack is called "bike rack" in their marketing and is welded directly to the frame and carries a 250lb load capacity. We have used this many times to mount 4 bikes by alternating direction of the bike and ratchet strapping them to the vertical pole that installs on the back side of the rack. The problem is, no matter what we do the bikes destroy each other. Some have areas rubbed down to metal and we have broken cables as well. We have tried pool noddles and blankets but nothing works when they are pulled tight so we are searching for a solution.
What I have seen so far is well mount things like this https://www.amazon.com/Stromberg-Carlson-CC-125-Cargo-Adapter/dp/B007VUXP1S/ref=asc_df_B007VUXP1S/
Has anyone used these? And, if so, how could I fit 4 sets? We know we can actually fit 5 bikes on our rack but that is super tight. Any other ideas for mounting and securing safely but without destroying bikes? We seem to have bad luck with bikes. Seems like any type of rack we buy including some expensive Thule hitch mount for our other car end up causing some sort of damage. Anyway, thought are appreciated. Thanks!
EDIT: Shortened the URL
