RJCorazza
Dec 03, 2015Explorer
The generator will struggle to unsuccessfully maintain voltage and frequency while shutting down under load. I suspect electronic devices could be damaged with low voltage and/or frequency.
Economy mode struggles to start heavy loads like motors, and may trip breakers before ramping up to speed. If you know you will be starting or using a high load device like a vacuum, microwave, etc, turn off economy mode first. For charging batteries you can likely leave it on.
My Yamaha also has these recommendations. Even starting my small vacuum cleaner with a 2000w generator with economy mode on is difficult, and doesn't sound good either for the vacuum or the generator. Enjoy your purchase!!!
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
