Golden_HVAC
Aug 30, 2014Explorer
The easy way to check your system.
After removing the cover, look where the electricians put the grounds and white wires. If this is the 'meter' panel, then the grounds and white wires will be attached to the same bussbars.
If this is a subpanel, then the white bussbar will be on one side, the ground in another location. You will have several wires going to the panel, 2-3 to the center bussbars and the circuit breakers going out of the panel (or a main circuit breaker) and the white wire to the white bussbar, the ground wire to the grounding bussbar.
Fred.
Fred.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
