magnusfide's avatar
magnusfide
Explorer II
Aug 25, 2014
50 Ways to Lighten Your RV
A forum member mentioned the need to de-clutter the rv. Thought a thread of ideas from the rveterans could be useful.
1. Kitchen: use knives instead processors. A set of 3 sharp knives are easy to use; easy to clean; and can be mounted on the inside of the cabinet door.
2. Buy the bottled beverages locally instead of packing them for breakage. Go into the local town and you might discover a new favorite wine or microbrew. One trip we discovered mead and had them ship a case to the house. Traveling is about new experiences too.
  • We full time so it's easy to keep packing stuff in if not careful.
    We don't buy a lot of canned goods at one time. We buy a few as we travel.
    Fresh water tank 1/2 full. Dump tanks before long travel.
    Every 6 months, go through everything and get rid of things we haven't used in last year.
  • 50. Relax, you aren't going to get good MPG regardless, so if you want something, take it (assuming you bough a capable truck that isn't overloaded with an empty RV). The nice thing about an RV over tenting is you leave all the camping gear in the rig and just hook up and go. When you decide you want something, it's in the RV not back in the garage.
    The easiest and probably most effective thing is to run with the tanks empty. That will eliminate a lot of weight (as in hundreds of pounds). The exception being boondocking take enough fresh water but consider if you can fill up close to the destination.
  • We only bring balsa fire wood and drink non fat milk. Everyoe uses the rest room before we leave. OK trying to be funny. I do go through the rig once a year and thin out stuff. But really, even in our rig a hundred pounds is not noticable. Don't worry about it.
  • We use paper plates, mostly for ease of clean-up, but they do save a bit of weight over china.
