4wlow's avatar
4wlow
5th wheel nose high problem
I have a 2014 ram 3500 with the 5th wheel prelp and a reese select hitch with the picture fame adapter towing a 2013 voltage 3200 with a trail air pinbox. Hitch is as low as it can go and the pin box is as high as it can go. I have 11 inches of clearance from top of bed to 5th wheel. Hitched up I am around 10 inches nose high. I know this is probably too much. Any sugestions? I already looked at other hitches like the Andersen ultimate, but that would only get me around an inch and a half lower. I plan on weighing the axles. Is my only option to raise the trailer?
  • rhagfo's avatar
    rhagfo
    Explorer III
    rtate wrote:
    I have the same problem except and the same truck. My axels are already on the bottom of the springs. I have about 7 inches clerance from the bed which is as close as I want to get. The trailer tows great. I am going to leave mine like it is unless my tires indicate the back axel is carrying too much load. I think the trailer suspension equalizes the load.
    You are noticeably pin high 4" to 11" I sure be working to get the 5er closer to level. Go to a weigh station and weigh the individual axles, I think you will be surprised at the weight difference.
    I am only about 2" to 3" pin high and still working to get level.
    This is not the best picture (sun glare and finger in picture), but it does show I am still a bit pine high. Likely going for the Lippert alignment kit.
  • I have the same truck with a pullrite slide hitch and a 2000 Coachmen flat front 101" width. I just did the axle flip for 6 in, raised the pin 2 1/2 in, installed low profile feet 1 1/2 in. Its sitting at 12 ' 10" at the ac/front vent cover.
  • Had someone with the same problem he ended up getting the factory air ride put on his truck tows level now 2,700.00
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
