MLWalton's avatar
MLWalton
5th wheel or bumper pull
Hey, new guy here. I have a 2019 F-250 6.2L 3:73 and debating on getting a 5th wheel or bumper pull TT. The 5th wheel I'm looking at has a dry weight of 10k and is 35 feet in length where as the bumper pull is 39 feet in length and it's dry weight is 8300#. Please give me some opinions on why you would chose one over the other. Thank you all in advance for helping the new guy.
  • For starters forget the dry weight figures. The gross weight (GVWR) is the the number that matters. Will your truck with the 6.2L handle fully loaded trailers? I like the 5th wheel for it's stability in crosswinds but I don't like the steps to the bedroom but I do like that 5th wheels are easier to maneuver and backup.
  • General opinion is that a 5er tows more stable than an equal length TT. But you know what opinions are worth. Many say a TT set up properly tows just as well.
    The truck and 5er total length will be a LOT shorter than the truck and 39’ TT.
    The 5er will be easier to get into tight sites since you can back in a tighter turn.
    TT doesn’t have inside steps you have to go up and down. A plus.
    Most 5ers have a lot of storage space under the front elevated area.
    Pros and cons for each.
    But you do need to check your truck payload rating compared to hitch weight.
