- GrooverExplorer II
thegrindstaffs wrote:
oh really?? We would be completely fine with that. there's really no downside is there? other than having a dolly at the campsite.
That is the main disadvantage. I strongly suggest that you get one with brakes. Even towing behind a motorhome I like having all of the brakes that I can get. Anything that weighs over 3,500lbs is supposed to have brakes in most states but many dollies do not and use the excuse that the dolly is rated for less the 3,000lbs. Nevermind the other axle of the vehicle or the fact that many dollies do end up with more than 3,000lbs on them.
The other downsides are that you do have an extra piece equipment to maintain, that can be a pain to load and unload, they add about 450lbs to your rig, they sit low and are prone to dragging, you need to put magnetic lights on the vehicle being towed and worst of all, you have to crawl under them in whatever weather situation that you are in to tie down the vehicle that you are towing.
On the flip side, they don't cost much more than adding brakes to a toad, no vehicle alterations are required and you can back them up a little if you have a backup camera that lets you watch for a jacknife situation. You can tow a rearwheel drive vehicle loaded backwards, just be sure to lash the steering wheel in place. Don't count on the steering wheel lock to hold it while towing backwards. - carringbExplorerPrevious generation (through 2019) Ford Explorer is flat-towable. My sister has a 2016 Explorer Sport and really likes it, and the only only issues over 80,000 miles were dealer caused (burned the clear coat removing the pinstripes and didn’t put the roof rails on right the first 2 tries). It also serves as the backup bad-weather tow vehicle for my brother’s Toy Hauler.
Also the Ford Flex is flat-towable. Same platform as the Explorer but lower, and has a longer wheelbase, so it’s both roomier and handles better. - thegrindstaffsExplorergreat! thank you very much for the help. For no reason at all, we never considered a dolly.
- trailernoviceExplorerread the article I sent a link to...it discusses 'alternatives to flat-towing', one of which is a dolly
- thegrindstaffsExploreroh really?? We would be completely fine with that. there's really no downside is there? other than having a dolly at the campsite.
- p220sigmanExplorerIf you are open to dolly towing, you open up your options to most any front wheel drive vehicle including most mini vans. Most will be under 5K curb weight and can comfortably seat 6.
- thegrindstaffsExplorerthank you!
- trailernoviceExplorerThis is why Google was invented...this search: "minivan or suv that can be flat-towed" produced this result:
https://rvblogger.com/blog/cars-flat-towed-behind-an-rv/ - thegrindstaffsExplorerhow can you find out what can be towed 4 down?
- colliehaulerExplorer IIII typed in 3rd row seating SUV and came up with several just pick one under your weight limit and brand preferance.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Aug 30, 2022
