- SeniorfirsttimeExplorerI also read info on this subject on the VW site...SAMBA...and a big recommendation was to put weight...sand bags...over the gas tank. Makes sense.
- SeniorfirsttimeExplorerA lot of references to the steering wheel bungee but still not sure how it's attached...up and down...side to side...and to what.
wolfe10 wrote:
Yes, you do have a steering dampner:
=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=clk0jl6v9eftt2agengfd3qr66]http://www.rockauto.com/catalog/raframecatalog.php?carcode=900534&parttype=7412&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=clk0jl6v9eftt2agengfd3qr66
I just never noticed it. - wolfe10Explorer
Big Katuna wrote:
67 was arguably the best year. First year of 12 volt, last year of baby buggy bumpers. last year of painted, no-plastic dash, 1500cc.
I agree.
And, looking back we did some really scary things with a 1967. It really would peg the 90 MPH speedometer-- the only stock beetle to do so. Of course a 3 MPH cross wind would have made that suicidal. There was so little weight on the front that factory recommended tire pressure was below 20 PSI! - Big_KatunaExplorer II67 was arguably the best year. First year of 12 volt, last year of baby buggy bumpers. last year of painted, no-plastic dash, 1500cc.
I towed bugs a lot. I recommend bungies on the steering wheel to help prevent wobble.
I also put a street ell in the trans fill hole to get another inch of oil in there but I dont think its required.
Old VWs are going through the roof, esp vans. Restored window vans are going for $50k and more. - wolfe10Explorer
- IvylogExplorer IIII learn how to pass in a 36 HP beetle... you lay back and when you think there's a hole coming up, you get a running start and turn off the AC IF it had one. I still use this technique and in the MH and I do not turn the AC off and it's a lot easier to see what's coming up. You run the bungee to the seat because the VW is so lite on the front.
A tow bar is only $100 and pins to the front axle lower torsion bar. I would be afraid of trying to put a "normal" tow bar that folds up as there is very little structure in the front of a beetle. - subtrollExplorerWe towed our 71 Super Beetle 2 years around the country using a low- cost JC Whitney tow bar and had zero towing problems. I did require several sand bags (150 lbs) in the front compartment to keep the front wheels tracking properly. I also used a bungy cord to make sure the transmission didn't jump into gear after a bump.
The bug was a real attention getter in campgrounds as many would stop and reminisce about their first-love car. Received several offers to sell it.
Still have the car but shifted to a jeep toad because I didn't feel safe on side trips on western freeways with high speed traffic. Also loading my generation folks in the backseat is a nightmare. - gboppExplorerThe only toad cooler than a VW Beetle is a VW Micro bus. :C
- Tom_BarbExplorer
Seniorfirsttimer wrote:
Tom, your 70 was a generation up from mine and I'm not familiar with the Baja but it sounds like you had a keeper.
two kids learned to drive on it, both used it to commute to collage, I commuted to work with it. In 600,000 miles I think the only thing I didn't change was the VIN.
I never needed the bungee. maybe because it was jacked up, 6", The tow bar was a simple "A" that attached to the front axel. no stabilizer nothing, it was steady as it could be.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
