CavemanCharlie
Mar 29, 2015Explorer III
Are you sure it's not working when you are moving? If set up correctly it should work so well that you may have a hard time telling the difference in braking from when you are not towing.
Find a safe place where you don't need taillights. Then stop with the connector plugged into the truck and measure the distance. Then unplug the connector and do the test the same way again and measure the distance.
Maybe it's working and you just don't know it.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
