BurbMan wrote:
I would slow enough to drop into 2nd at the top of the hill, possible 1st depending on how twisty/turny. Leave it in tow/haul, that provides additional engine braking. I know on the burb 2nd gear limits speed to 45, 1st gear to about 30 on these steep grades. As long as no sharp curves I am OK at 45.
Personally I can’t believe all the ideas tossed into this thread!
I wasn't going to reply any more but there is so much utter nonsense being posted which is simply going to make more confusion..
Each vehicle has it's own characteristics, one vehicles "2nd gear" just may be 3rd gear or another vehicles 1st gear. So there IS NO SET IN STONE RULE as to what speed or gear to be in..
Tow/Haul MAKES this much easier to tow and takes a lot of guess work out of it..
Folks READ THE MANUAL.
PATSROCK, you did not give the year of your truck but here is the Owners manual for our 2006 F250.
Pay attention the points I bolded.
2006 F250 Owners Manual LinkPages 176-178..
Understanding the shift positions of the 5–speed automatic
transmission
This vehicle is equipped with an adaptive Transmission Shift Strategy.
Adaptive Shift Strategy offers the optimal transmission operation and
shift quality. When the vehicle’s battery has been disconnected for any type of service or repair, the transmission will need to relearn the normal shift strategy parameters, much like having to reset your radio stations when your vehicle battery has been disconnected.
The Adaptive Transmission Strategy allows the transmission to relearn these operating parameters. This learning process could take several transmission upshifts and downshifts; during this learning process, slightly firmer shifts may occur. After this learning process, normal shift feel and shift scheduling will resume.
D (Overdrive) with Tow/Haul OFF
D (Overdrive) with Tow/Haul OFF is the normal driving position for the
best fuel economy. The overdrive function allows automatic upshifts and downshifts through gears one through five.
D (Overdrive) with Tow/Haul ON
The Tow/Haul feature improves transmission operation when towing a
trailer or a heavy load. All transmission gear ranges are available when using Tow/Haul.
To activate Tow/Haul, press the
button on the end of the gearshift
lever.
The TOW HAUL indicator light will
illuminate in the instrument cluster.
Tow/Haul delays upshifts to reduce frequency of transmission shifting.
Tow/Haul also provides engine braking in all forward gears when the
transmission is in the D (Overdrive) position; this engine braking will slow the vehicle and assist the driver in controlling the vehicle when descending a grade.
Depending on driving conditions and load conditions, the transmission may downshift, slow the vehicle and control the vehicle speed when descending a hill, without the accelerator pedal being pressed. The amount of downshift braking provided will vary based upon the amount the brake pedal is depressed.To deactivate the Tow/Haul feature and return to normal driving mode,
press the button on the end of the gearshift lever. The TOW HAUL light
will no longer be illuminated.
When you shut-off and restart the engine, the transmission will
automatically return to normal D (Overdrive) mode (Tow/Haul OFF).
Do not use the Tow/Haul feature when driving in icy or slippery
conditions as the increased engine braking can cause the rear
wheels to slide and the vehicle to swing around with the possible loss
of vehicle control
The transmission will not downshift into 1 (First) at high speeds; it
will downshift to a lower gear and then shift into 1 (First) when the
vehicle reaches slower speedsOver the years Ford has made significant enhancement changes to the Tow/Haul feature, our 2013 the Tow/Haul works even better than the 2006 version.
To be very clear, these transmissions NEED to be placed in Tow/Haul AND KEPT IN TOW/HAUL while towing.
This allows the transmission to RELEARN AND ADAPT to the load. Randomly turning on/off Tow/haul or manually downshifting when you think you need or don’t need it makes no sense and you are not taking FULL advantage of the Tow/Haul feature. Not to mention the transmission NEVER learns and adapts CORRECTLY to your towing conditions when you are constantly overriding the Tow/Haul feature.
In order for the Tow/Haul feature to work CORRECTLY you MUST keep the Tow/Haul ON.
If you keep the Tow/Haul on it WILL AUTOMATICALLY DOWNSHIFT FOR YOU. This is DEPENDING ON DRIVING CONDITIONS AND LOAD CONDITIONS.
The AMOUNT of downshift braking WILL VARY BASED ON THE AMOUNT OF BRAKE PEDAL PRESSURE (IE how many gears it downshifts).
If Tow/Haul does not automatically downshift you simply Press on the BRAKE PEDAL, the more pressure you apply the more aggressive the downshift will be.
Keeping in mind that the transmission WILL NOT DOWNSHIFT to the next lower gear if your speed is excessive for the next lower gear to protect the engine and transmission. You cannot override this feature even if you manually select a gear, the transmission will only downshift when it is safe to do so. In other words if you are 4th and select 1st it will only go to 3rd until the speed has reduced enough to safely shift to 2nd and so on..
PATSROCK, READ YOUR MANUAL.
The highway system ALSO GIVES you advanced notice of any steep grades so all you need to do is to be aware of them. When you SEE a down hill grade sign and before you start down the grade,
let off the throttle THE WHOLE WAY (LIFT YOUR FOOT OFF THE THROTTLE PEDAL). This will allow you to lose some speed and let the Tow/haul do its job (you must let up on the throttle to get Tow/Haul to downshift).
If you feel the downshift is not happening fast enough or it has downshifted and is gaining speed simply press on the brake pedal until it downshifts to the next lower gear.. When it downshifts you can let up on the brake and simply watch to see the speed is no longer increasing.
You MAY need to apply brakes periodically on long grades to maintain a safe speed but you should not need to continuously ride the brakes nor be pressing hard the whole grade as long as the Tow/Haul has downshifted far enough.. If you do have to use the brakes Tow/Haul SHOULD downshift to a lower gear all the way down to 1st IF NEEDED provided the RPMs are within the safe area to do so.
The last time I manually downshifted was with my 2003 F250 which did not have tow/haul..
The highway systems will also have signs posted for truckers which often will post max safe speeds for truckers, towing heavy as you are you should HEED the posted trucker speed limits for those grades. Unlike a lot of RV "towers" I tend to fall in line with the truckers when going down long steep grades and maintain similar speeds as they are doing.
Not to mention that if there is hairpin turns and such those will have posted truck speeds.
You can at any time find Ford Owners manuals online..
FORD TRUCK OWNERS MANUALS
