Cummins12V98 wrote:
SoundGuy wrote:
Cummins12V98 wrote:
"According to Endurance owners the tire is stamped on the sidewall "inflate to xx psi"."
I bought a set this summer for my tandem axle boat trailer. I weighed the trailer and run 55psi instead of the 65 on sidewall. I will have to investigate further but I am fairly certain it says "MAX inflation 65psi".
In fact what is imprinted on the sidewall of a Goodyear Endurance tire is - "FOR MAX LOAD INFLATE TO XX PSI". In the case of my ST205/75 R14 Endurance that XX would be 65 p.s.i. which is how I run mine on wheels which previously wore off shore shoes in a C load range rated for 50 p.s.i. Some new Endurance owners seem to want to run less than full rated pressure but I wouldn't be one of them - mine run great at their maximum rated 65 p.s.i.
Please explain WHY you run full psi when your load may only require 55psi?
1) higher inflation will give more load carrying margin
2) higher inflation will reduce heat buildup
3) higher inflation will help for lateral load stability
And, based on my experience and 3 friends with trailers, we all run at or near max inflation with tires that have a large load margin, and none of us have seen excessive center tread wear, wear has been very even and when we need to replace them every 25K-30K miles, nice even wear.
The old, overinflate center tread wear was a much bigger issue with bias ply tires. Much less an issue with radial ply tires.
Now, on cars and trucks way overinflation certainly has undesireable consequence.
go look at your TV or car sometime and compare the recomended inflation pressure and load at that pressure compared to actual tire load when not towing. You'll likely find that the recomended inflation pressure is noticeably above what it would be if you just went by load alone.
