cbshoestring's avatar
cbshoestring
Explorer II
Jul 03, 2016
87. Volt. Are you on the fence about buying surge protection
I was told A/C could not be used, and friends who have stayed by the lake warned it was a single receptacle. Still, I paid for electric, I hoped I could at least make coffee.
87 volts when it first cycled, 94 by the time I took the pic, then rolled up my power cord
I guess we will run the fridge on propane, limit our battery use. I plugged Mr Coffee directly into the pole. Better a $20
00 coffee pot..inverters are expensive.
I guess I can re-hook to the truck for a daily "recharge".
[img][/img]
  • A surge protector alone won't do you any good in a scenario like this ... what you want is a full feature EMS that can detect a variety of power source errors, including high and low voltage, in this case the latter. So ... what's the point of your post? :h
    FWIW, your situation is exactly why I installed a 1000 watt PSW inverter - not for planned dry camping (which we do little very little) but for those emergency times when we lose campground power for one reason or another but would still like to have limited use of 120 vac to power a toaster, or coffee machine, couple of fans, etc. I've wired the inverter output to dedicated receptacles in the camper and because my trailer is protected with a Progressive Industries WMS-HW30C I can leave the trailer's main service cable plugged into the campsite power post and allow it to continuously monitor the power source and decide when / if it's safe to turn back on again. No surge protector alone will do that. ;)
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
