Fastfwd75's avatar
Fastfwd75
921 bulb low light replacement or 12v dimmer possible?
I find that the lights are much too bright at night when I just need to see enough to move around. What are compatible lights to the 921 socket that would put out less light or is there an easy way to add a dimmer?
    Take the bulb that fits the socket to a NAPA store. By using the number on the bulb they can look up other bulbs of less lumens,(Brightness) that will fit.
  • The 921 bulbs also get way too hot, I replaced mine with 48SMD LED panels. I get more light and a lot less heat. :)
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
