BenK
Feb 21, 2019Explorer
Before getting PM’s tomorrow morning...
Load up both TV and trailer. WD system fully tensioned
Go to a CAT scale and weigh the whole setup and the CAT Scale should also provide weights for each axle of the whole setup. TV front, rear and trailer
Then without moving, disconnect the WD bars (remove all tension) and reweigh EVERYTHING again
Now you will have the weights indicating where the tongue weight was distributed
PS...if you have an Anderson...it WD’s differently than a traditional setup as described above
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
