Im new to solar in the RV and noticed that it's 0 ampere, while the battery is fully charged 100 percent and the volts is 13.6. Sorry im not good with elxtricity nor solar but What's with the 0 am...
Amperage is the amount of electrical flow. If the battery is charged and not being used, there will no flow of electrical power. That is normal.
If the solar is producing and the battery is being used and/or discharged, the amperage will be higher than 0. Depends on your system and the drain as to how high the amperage will be.
Sounds like your system is fine. I home this helps.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
