BarneyS
Jun 06, 2014Nomad
Jonnygsx wrote:BarneyS wrote:
I did what you are going to do a couple of years ago and posted about it, with pictures, here.
It is still holding up very well.
Barney
Looks great Barney. Ha you have the same ladder I do, were you able to walk on your roof or did you have to keep moving your ladder around? Ive been told I can't walk on my roof which is going to make applying this 10x harder.
That is a great ladder. It is perfect for carrying in the back of the truck.
I was able to walk on my roof to do the job. I cannot imagine trying to do it otherwise. You have to pour the stuff on the roof, spread it out as even as possible with a squeegee, then go over it with the roller. This would be extremely difficult without being able to stand on the roof.
In your case, I would try to figure out some way to spread your weight around - like putting thin plywood sheets up there or making a scaffolding to work from. Otherwise, I think I would hire the job out for a different process. I don't think I would try to do it from the side while working from a ladder.
Barney
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
