jk31668's avatar
jk31668
ac & water heater at same time?
any idea if i can run my roof 13.5 ac at the same time as my 6 gal suburban water heater? i have a class c with 30 amp service. thanx
  • TNGW1500SE wrote:
    You should be able to. Turning the A/C off to heat up water would be a pain.
    Heat water using propane....same with fridge
    Doing so lessens the electric load
  • Should be ok. Just don't also try microwave, hair dryer, electric skillet, or such at the same time. Worst that can happen is the breaker will trip and you will have to reset it.
  • You should be able to. Turning the A/C off to heat up water would be a pain.
  • Depends on what you are connected to for AC power.
    15A outlet..NO
    30A outlet.....YES
    50A outlet.....YES
    Generator......maybe
    Depends on generator rating
    One only needs to 'try' it to find out.....CB trips then NO
