- Old-BiscuitExplorer III
TNGW1500SE wrote:
You should be able to. Turning the A/C off to heat up water would be a pain.
Heat water using propane....same with fridge
Doing so lessens the electric load - BB_TXNomadShould be ok. Just don't also try microwave, hair dryer, electric skillet, or such at the same time. Worst that can happen is the breaker will trip and you will have to reset it.
- TNGW1500SEExplorerYou should be able to. Turning the A/C off to heat up water would be a pain.
- Old-BiscuitExplorer IIIDepends on what you are connected to for AC power.
15A outlet..NO
30A outlet.....YES
50A outlet.....YES
Generator......maybe
Depends on generator rating
One only needs to 'try' it to find out.....CB trips then NO - 2oldmanExplorer IIAnd the answer is: maybe.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
