I have a 31 ft' fifth wheel. The air conditioner was installed incorrectly at the factory. They left the divider off that separated the input and output air so it just churned and didn't cool. Made a makeshift divider and fixed that problem so now the air conditioner works fine. You might want to remove the inner panel to make sure you have good separation with no lair leaks between chambers.
Our trailer has a bunch of windows. If is going to be hot, we have to start the air when it is still cool outside to give it a fighting chance, blinds down. Involves some sweater time in the morning.
We're in the northwest so it always cools down at night and we never sleep with the air on. You might want to disregard this if it stays hot all the time where you are.
We also had a Bigfoot trailer with a 22 ft. box, dual pane windows and very good insulation. I figured one could make ice cubes on the counter with the air conditioning in there if they wanted to.
